emeraldlion Posted January 15, 2012 Share Posted January 15, 2012 Has anyone attached the trim ring to their 280 tail ilght in a fashion that did not require the tiny screws? Most of the pot metal for each screw is cracked and does not hold well. I was also unable to find screws with a shaft small enough to fit. Any alternative suggestions? Quote Link to comment Share on other sites More sharing options...
HaaJeHaa Posted January 15, 2012 Share Posted January 15, 2012 tec7;) Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted January 15, 2012 Author Share Posted January 15, 2012 Thanks, that's the route I felt I was going to go, but wasn't sure if there was enough lip to get decent adhesion. The only thing I don't like is the thought of not being able to take it off to touch up paint, oh well. Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted January 15, 2012 Share Posted January 15, 2012 I used RTV sealant. If in the case that I had to remove them again and Rechrome them I could easily remove the trim from the surrounding light housing. Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted January 15, 2012 Author Share Posted January 15, 2012 And that held it on sufficiently? Sounds like a better option. I have some black silicone sealant in the garage from sealing the trans tunnel. Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted January 15, 2012 Share Posted January 15, 2012 And that held it on sufficiently? Sounds like a better option. I have some black silicone sealant in the garage from sealing the trans tunnel. Yes. Holds it in just fine. Good enough hold to keep it in yet not permanent so you can remove it later for whatever reason needed. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 16, 2012 Share Posted January 16, 2012 I used to use 3m double sided tape. Quote Link to comment Share on other sites More sharing options...
