Rocker rail seam referece piont
I'm assuming you are referring to an early Z, as well as referring to the seam underneath the rocker, and also assuming you are asking because you want to slam the car.
From my recollection, on a 240z the floor is higher than the rocker as is the frame rail (hence why it's called the rocker, so you can rock your car on it if it becomes stuck on a crest). The cross member is also higher as the frame rail bends up near the engine bay, and the cross member is mounted under that. I think the lowest point becomes the exhaust and oil pan. Possible the diff and control arms depending on how small of a tire you run.
