cas connections Pin2 ?
macambra
Which lead are you concerned about?
Pin 2 on the MS DB37 connector is a ground.
You should run the CAS signal to pin 24. If you have a pre-assembled V3.57 board, you can install the 1K Ohm pullup resistor internally on R57. It keeps the wiring cleaner. You should use shielded wire with the shield grounded at the MS.
The other CAS signal wire can be left alone / disconnected.
The difference in the two pics you posted is that the megamanual install is getting the tach signal from the coil neg. The DIY install is getting the CAS from the 280ZXT optical pickup and then driving the coil.
Sam
Sam
OK,so do I need to gound pin 2? Sounds like it's internally grounded...
