jacob80 Posted February 19, 2012 Share Posted February 19, 2012 Good evening all, I wanted to touch base with all of you regarding Megasquirt 2 and its capabilities, requirements, and this TunerStudio deal I knew nothing about. Now, I will say, I haven't done tons of research, and it is all very scattered, so I am still working up the courage to culminate information from MSExtra, here, and other various websites. But, in the mean time and between time, I'm going to post a couple questions for you guys here. First off, as far as installing the Megasquirt 2 daughter board, I've read mixed things about whether there are wiring requirements. Is it just a plug and play application, or do I need to wire a +12V source for this stepper motor controller? What have you guys done in the past? Before I get too far, I will say that this is a V3.0 board that was previously utilizing the BIP373 ignition module. Also, I'm reading that I can no longer use MegaTune and that I must switch to TunerStudio if I want to run MSExtra for Megasquirt 2? Is this true? I'm not opposed to it, as long as it is just as intuitive, but it is definitely something I am not used to. Thanks for your help boys. Quote Link to comment Share on other sites More sharing options...
macambra Posted February 20, 2012 Share Posted February 20, 2012 Reading the manuals (megamanual and msextra manual) will answer your questions. There is a cornicopia of info, so decide what exactly you want ms to do for you, read the manual for the apropriate parts, then start asking questions. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted February 21, 2012 Share Posted February 21, 2012 You do have to put a jumper wire for 12 volts to power the stepper motor controller. If you are not using a stepper motor for idle control then you don't have to do that. Everyone should be using tuner studio at this point even though it is different and causes a learning curve. It is a much better tuning program. Megatune is no longer supported or updated. Quote Link to comment Share on other sites More sharing options...
