280z Turbo Missing.
Fixed some things and got my 280z Turbo conversion running and on the road, My problem now is it misses pretty bad at idle and when holding a steady RPM. The car seems to be fine in boost but out of boost I get the slight feeling of hesitation, but my timing is set right at 20BTDC like the FSM states, plugs are gaped at 32 because I was getting spark blowout. I have a GM Igniter module but have not yet done the swap. Any ideas what else I should check before/after I do the igniter conversion.
  On 2/25/2012 at 7:19 AM, Grip_Z said:
52k and burns no oil. Runs a little rich. Pulled the plugs after cruising and all are dry aside from #1. Should also mention I get a puff of black smoke when starting it in the morning, from it being rich.
im guessing you are running an afm? search how to adjust the afm and try that out. weird that only one cylinder is wet.
