JTR Radiator Bracket Dimensions
JTR chapter 12 on cooling gives the radiator dimensions, but not the brackets. I haven't tried asking JTR yet, but I don't think they made them themselves. It sounds like they were buying them from someone else. The bottom one seems easy enough to make; the top one seems tougher because of the 'wings' that come down to attach to the original holes. I might try some old Chevy truck top brackets if I can find them locally, then make the bottom bracket as deep as it needs to be.
  On 3/11/2012 at 5:50 AM, 280~Master said:
Here is a copy of my lower bracket, I had it made up for my radiator conversion from JTR and it fits great.
I have a 76 280z.
As for the top I did something a little different.
I had a Bracket made up to resemble the top bracket of a I-Rock Camaro.
That's basically what I did for the bottom. Looks like we came up with the same numbers. I was thinking for the top I might be able to use upper mounts from a 67-72 Chevy truck. It would drop the radiator slightly, which I'm thinking I could compensate for by making the lower one a little deeper.
