MazerRackham Posted March 9, 2012 Share Posted March 9, 2012 (edited) So, using that scan as a reference, where do I put the clampies? I took my fuel injectors out to be rebuilt and serviced yesterday and today the front yard smells like gasoline. I think I need clampies before my fuel tank is gone and my neighbors get angry. Thanks guys!! I may scan my entire Clymers's Datsun manual 4 u <3 I think I am going to start another thread for this separate problem, but after a day of sitting my car will need to have the fuel pump "primed" by me pressing the potentiometer on the airflow sensor forward. After that I get in the car, start it and she runs fine. Is this indicative of a cold start injector failing or something?? Edited March 9, 2012 by MazerRackham Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 9, 2012 Share Posted March 9, 2012 At 7 & 8 on your diagram. Quote Link to comment Share on other sites More sharing options...
MazerRackham Posted March 9, 2012 Author Share Posted March 9, 2012 Thank you brother!! Also, if you don't mind answering, do have any idea of how I would go about solving the question I added to the topic post? Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 9, 2012 Share Posted March 9, 2012 Discharge Check Valve on the pump. You can buy the replacement there is a part number (maybe Volvo...someone posted it) or add an aftermarket one-way valve. Chances are good it's not 'bleeding down' on the front end. The usual culprit on the front end is an FPR seat. With application of the clamps and gauges in various positions, you can isolate where your loss is occurring pretty easily. It's also been posted previously. "Walk the circuit" with gauges in place. Clamp before fuel filter and at 8 and see what happens to the pressure in the rail overnight. If it stays there, chances are the pump check valve is a leaker. If its bled down, then since the FPR return is closed then it's an injector leak of some sort. Quote Link to comment Share on other sites More sharing options...
MazerRackham Posted March 9, 2012 Author Share Posted March 9, 2012 Did I ever mention that I ******* love you guys?? Quote Link to comment Share on other sites More sharing options...
MazerRackham Posted March 10, 2012 Author Share Posted March 10, 2012 Discharge Check Valve on the pump. You can buy the replacement there is a part number (maybe Volvo...someone posted it) or add an aftermarket one-way valve. Chances are good it's not 'bleeding down' on the front end. The usual culprit on the front end is an FPR seat. With application of the clamps and gauges in various positions, you can isolate where your loss is occurring pretty easily. It's also been posted previously. "Walk the circuit" with gauges in place. Clamp before fuel filter and at 8 and see what happens to the pressure in the rail overnight. If it stays there, chances are the pump check valve is a leaker. If its bled down, then since the FPR return is closed then it's an injector leak of some sort. So, ideally, I would see that the pressure has gone up since placing a clamp on 8 if nothing were wrong? Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 10, 2012 Share Posted March 10, 2012 I don't know what scenario would make it "go up" unless your reference was zero. You clamp it while running, and it will go up to fuel pump internal bypass pressure (about 60) which is why I said place the clamps immediately at time of shutoff. You will lock what pressure is in the lines and prevent it from either bleeding backwards through the pump, or from the FPR depending on where you place the VG. Don't overthink it, do the test and see what happens. Observe and report. It will come to you as you do it. We can talk all day and some people wont get it. The put the first clamp on and it goes 'flick the switch' OOOOOOOOOOOOOOH! Quote Link to comment Share on other sites More sharing options...
