SU Float Level and Engine Angle
Mark Fraser
I am trying to get the float level set correctly on my SU carbs but just can’t make them workout. I want both carb levels to be the same height down from the bridge. My front float level is about the right height but the rear one is about 1/4†lower that is should be. If I bend the tab to raise the level, the float hits the float chamber side and fuel spills over the top. I have even tried drilling a new pivot point higher in the float chamber but that has not worked either. One possible cause of this height difference is my engine sits at a 3 degree angle with the front being higher than the rear. Should a Z engine sit level in the engine bay? Thanks for any help on this.
Mark
What do you mean by "If I bend the tab to raise the level, the float hits the float chamber side"?
To hit the side, you mean the float is not traveling straight up?
I assume you've already looked the stuff up, if not:
http://www.jetlink.net/~okayfine/su/sutech.html#anchor108396
http://www.jetlink.net/~okayfine/su/moreinfo.html
ss
Edited by steve260z
