Dadaluma Posted March 17, 2012 Share Posted March 17, 2012 Hello again, still trying to get my car running correctly, My question is I am running the Extra code 3.2.1 on my megasquirt 2 3.0 board, but I assembled the board to the regular assembly instructions on the megasquirt main site. Is this okay or are there differences in the assembly process that would interfere with operation. Should I switch back to the standard code or change the board to reflect the msextra install. Thank you Quote Link to comment Share on other sites More sharing options...
Dadaluma Posted March 18, 2012 Author Share Posted March 18, 2012 I found the info I needed, thank you Quote Link to comment Share on other sites More sharing options...
Leon Posted March 19, 2012 Share Posted March 19, 2012 I found the info I needed, thank you Care to post the answer, to archive for the search engine? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted March 20, 2012 Share Posted March 20, 2012 The regular build guide can be used if you're using the Extra code; it just doesn't include mods for some of the extra I/O the Extra code allows. Quote Link to comment Share on other sites More sharing options...
akeboshi Posted March 26, 2012 Share Posted March 26, 2012 Just a quick side note, the standard stim board doesnt support the tach input for the extra code. Example is I had a motor running the 12-1 diy wheel with b&g code, works fine on motor and stim, same motor and same stim with extra code = no bueno amigo with the stim. I had to use the engine to check the firmware LOL. Im running extra code boooyyyy! Quote Link to comment Share on other sites More sharing options...
