'81-'83ZX speedometer Unit
Tennesseejed
Looking for a speedometer unit from a ZX or ZXT manual transmission (non-BW/T5).
I'm having troubles getting the 280Z speedo unit in my ZX 5 speed to work properly. Apparently the ZX units were slightly offset.
The color of the speedomer gear doesn't matter. I have the 17 tooth to match my diff.
Edited by Tennesseejed
Thanks, I'll look into that as a solution.
And it makes sense because the current speedo unit will work if its turned some.
Jed
EDIT:
NewZed, your advice worked like a charm. I flipped and slotted the 280Z speedo unit with a hand file. Took about 10 minutes and my speedometer is working again.
The collective knowlege here on HybridZ never ceases to amaze.
