Zdriver92 Posted May 18, 2012 Share Posted May 18, 2012 Hey guys, just bought a 80 280ZX and whenever I start up the car it fires right up no problems but after I let it warm up for about 15 mins it slowly loses its idle and eventually just dies out. After that happens I cannot start it up until its cold again. Any ideas on what the problem could be? I would really appreciate any help : ) Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 18, 2012 Share Posted May 18, 2012 Cylinder head temperature sensor (CHTS) maybe. Bad connection or faulty. See EF-26 in the FSM. www.xenons130.com/reference Quote Link to comment Share on other sites More sharing options...
jomz shakes Posted April 24, 2014 Share Posted April 24, 2014 Ignition control module. It's mounted w 2 screws I think onto your distributor. Got on wire harness that it plugs onto. Put ice in a bag and cool down that part maybe to try and see if that's the problem. Quote Link to comment Share on other sites More sharing options...
warrenHLS3083301 Posted May 17, 2014 Share Posted May 17, 2014 put a voltmeter on your fuel pump, I have the same problem, found out the voltage was dropping due to my cheap alarm system, from 13.5 down to 9 when the system arms itself, takes a minute or two to drop. ps i have the z31 ecu swap and this reverses fuel pump polarity at the relay, never died before the upgrade. Quote Link to comment Share on other sites More sharing options...
