R200 swap in a 70 Z
ciavola
I am restoring a 1970 Z , I am doing a R200 swap, I bought the M-bar, Control arm Hanger, Front Crossmember, and the r200 differential from a 280z. I am having an issue figureing out the mounting procedure. I installed everything and the strap that goes on top of the differential wouldnt fit over the bolts that holds the insulator on the front differential crossmember. so I figured it was incorrect so I dropped everything back out, reversed the insulator because i thought I had it backward( I had the bigger part towards the front of the car) so I flipped the insulator around and the strap now fits, but the differential is a half an inch from the mustach bar. and the drive shaft doesnt fit now.(too long) I can not figure what part of this I have incorrect. Ive searched for info and found basic info, but nothing that address these issues.
Chris
Others may have a different opinion, but I say ditch the strap and just work with the rubber insulator. The strap is just such a pain and I think it is only necessary if your rubber mount breaks. That will let you turn it (the insulator) around and get your diff installed. Then, save up for an RT (Ron Tyler) mount - it sort of solves all these diff mounting problems.
Are you are talking about the arrestor strap that goes over the front of the diff. If so the strap will not fit over the R200 as it is larger in diamanter than the R180. You might look into a Ron Tyler or a Technoversions front mount. They both work very well, And are easy to install. I have one in my early 260z, and it works great. ( http://www.technoversions.com/index.html ) The best way to mount it is to also get the top mount, and eliminate the factory lower mount. Check out his web site and look at his product. You won't be sorry.
If the RT mount will solve my problems, I will buy one, but which is the correct way to mount this? I have read different things about turning the M-bar around. reversing the bottom mount moves the differential towards the back of the car. I have never heard any mention of removing the strap all together in all the stuff I have read on any sites. Can any one confirm wich way the stock mount mounts. the wider side towards the back or the front?
It has been been awhile since I looked at my car, But with the R/T or technoversions front mount, you don't need to use the stock front mount as long as you get their urethane top mount. It bolts to the custom mount and to the diff. allowing the diff. to dolt to the m/bar and allows for the better axle shaft angles. I hope that this helps you to get your car back together soon. ( My Z is in Arizona and I just moved to Georgia. I hope to get it shipped here soon. ) The price on the Technoversions is about $100.00 shipped to your door.
Edited by jax 260z
You don't have to do any monkey business with the mustache bar with the RT mount - you just take off the stock front insulator and sell it on ebay! With the RT mount, you need to get the part number for the urethane bushing that bolts to it - it is not included in the RT mount. Then you just paint it and install it. I can walk you thru it if you have trouble. In the meantime, you'll be ok without the strap. If your bushing is new, you'd be ok for years unless you have a high torque engine.
what about using the bumper stop that comes with the RT Mount? bad? as opposed to the top mounted one? also is the RT with upper mount a straight bolt up on a 70? no fabricating? I also received an email that 72 and later used different strap brackets that allowed the stock strap? Thanks for the info..
Yes. Call or pm me when the mount arrives and you have it painted. You will need to cut a couple of clearance "reliefs" in your front cross member too so give me a holler when you have the front cross member off and a dremmel tool with a fiberglass cut off wheel. I am available most evenings but work days.
  • 3 weeks later...
I bought the R/T mount from technoversions and while it looks great the isolator that it comes with does not sit flat on the top of the nose of the diff???? Any one have a picture of one installed? The mount was pretty cheap and really looks like a quality part, just hope it works now.
Edited by Wheeler
I talked to them when I was installing my mount. they said you can either grind off some of the plastic from the mount, or shim it away from the diff. ( that is what I did ) I had no problem using shims,as you want the mount to conform to the top of the diff. I hope this helps you.
  • 4 weeks later...
That second part number is for a rebound snubber under the nose of the diff and the crossmember. The RT mount still allows a fair amount of movement and I still had some clunk until I put a snubber under it too. Still a little clunk but but much much less.
  • 3 weeks later...
Its so much simpler to swap in a 4.11 r180 because your going from r180 to r180. The 720 4.11 r180 uses bolt in axles like your z. The 200sx r180 requires clip in axles or a button swap from your old r180. Though I HIGHLY recommend not altering the r180. When you start taking it apart you have to assemble it with tolerances and great care. See how I messed up by removing the side retainers in my thread, 4.11 r180 problem. I likely ruined it by my ignorance.
