baja12 Posted May 21, 2012 Share Posted May 21, 2012 hi guys i just bought my first z and the analog dash didnt work when i got it...when i turn the key nothing comes on but the radio...battery is good if i go to start it will crank will start if starting fluid is put into plenum...also i believe that whatever is making the dash not come on is also what is not making the fuel pump come on...i dont hear it when key is on...could it be my ignition switch? Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted May 22, 2012 Share Posted May 22, 2012 Yes it could be the wires that come off the ignition switch/module. They may be fried or rusted. Pull that out and check all the soldering points for continuity. Quote Link to comment Share on other sites More sharing options...
85zxt Posted June 16, 2012 Share Posted June 16, 2012 hi guys i just bought my first z and the analog dash didnt work when i got it...when i turn the key nothing comes on but the radio...battery is good if i go to start it will crank will start if starting fluid is put into plenum...also i believe that whatever is making the dash not come on is also what is not making the fuel pump come on...i dont hear it when key is on...could it be my ignition switch? Put a fuel pressure gauge in line. 30-35psi should show. If not probably need fuel pump. Usually digi dash is a problem with power supply - is there a power supply to analog dash? Never looked. If so would be to right of steering column under dash. Quote Link to comment Share on other sites More sharing options...
