Dead Roman Posted June 28, 2012 Share Posted June 28, 2012 I would very much like to use an l28 for a motorcycle project but I have some questions and I have been doing quite bit of searching to find answers. I used to have a turbo motor for a z build but that is long gone now so I dont have any way of taking measurements or vizualizing what I need. 1. Could you theoretically run 6 small carbs, one for each cylinder? My thinking behind this would be to use very short individual intake manifolds. 2. Will there be any negative side effects to using very short intake manifolds( basically 1-2 inches long) 3. Is there any kind of "low profile" distributor design out there? Basically the smallest most unobtrusive ignition setup possible? Any way of getting rid of the distributor that O am not aware of? Quote Link to comment Share on other sites More sharing options...
ctc Posted June 28, 2012 Share Posted June 28, 2012 Try searching. Diddler(sp) on here is using GSXR throttle bodies. Carbs would work on the same principle. Runner length has been discussed, both pros and cons. A few have gone crank trigger and don't need the distributor. Search, then ask very specific questions or this will end up in the tool shed. Quote Link to comment Share on other sites More sharing options...
Dead Roman Posted June 28, 2012 Author Share Posted June 28, 2012 Im searching for info on the crank trigger setup but I am not having very good results. Could you steer me in the right direction please? Quote Link to comment Share on other sites More sharing options...
ctc Posted June 28, 2012 Share Posted June 28, 2012 My linkhttp://forums.hybridz.org/index.php/topic/77233-30-1-tooth-wheel-with-cherry-hall-effect-sensor/page__p__986937__hl__distributorless__fromsearch__1?do=findComment&comment=986937 http://forums.hybridz.org/index.php/topic/105480-distributorless-ignition/page__p__986655__hl__distributorless__fromsearch__1?do=findComment&comment=986655 http://forums.hybridz.org/index.php/topic/102458-my-edis-setup/page__p__958836__hl__distributorless__fromsearch__1?do=findComment&comment=958836 Wow, that took a minute. Also research Mega Jolt. See link below http://www.millersmule.com/MillersMuleStore/en/edis/54-megajolt-advance-controller.html Quote Link to comment Share on other sites More sharing options...
Dead Roman Posted June 28, 2012 Author Share Posted June 28, 2012 Thank you very much. I guess i was just using incorrect terms. Quote Link to comment Share on other sites More sharing options...
BlueStag Posted June 29, 2012 Share Posted June 29, 2012 I would very much like to use an l28 for a motorcycle project Wow. What sort of motorcycle takes a cast iron block straight six? Why do I have the feeling that this thing is not going to be brilliant at taking turns? Quote Link to comment Share on other sites More sharing options...
Dershum Posted June 29, 2012 Share Posted June 29, 2012 Wow. What sort of motorcycle takes a cast iron block straight six? Why do I have the feeling that this thing is not going to be brilliant at taking turns? A rather long and heavy one? Sounds like something out of Monster Garage... Quote Link to comment Share on other sites More sharing options...
Dead Roman Posted June 29, 2012 Author Share Posted June 29, 2012 Its just a goof around project. Its not gonna be very good at anything really. Going for an old, inline 4 indian boardtracker style look. Quote Link to comment Share on other sites More sharing options...
beermanpete Posted June 29, 2012 Share Posted June 29, 2012 Hopefully it won't turn out quite this large. Quote Link to comment Share on other sites More sharing options...
Dead Roman Posted June 29, 2012 Author Share Posted June 29, 2012 Probably wont rurn out at all, im thinking of going a different directio. Quote Link to comment Share on other sites More sharing options...
TimZ Posted June 30, 2012 Share Posted June 30, 2012 Hopefully it won't turn out quite this large. I've seen that bike in person! It's in the Motorcycle Museum in Anamosa, IA... Quote Link to comment Share on other sites More sharing options...
TimZ Posted June 30, 2012 Share Posted June 30, 2012 (edited) ...oops -double post Edited June 30, 2012 by TimZ Quote Link to comment Share on other sites More sharing options...
