dpuma8 Posted July 1, 2012 Share Posted July 1, 2012 Is there a way to identify if a transmission is a 5 speed or 4 speed by looking at it? I am at the pick and pull and I can't shift the gears to check but it does have a #5 stamped on it and an "L" on it Quote Link to comment Share on other sites More sharing options...
z240 Posted July 1, 2012 Share Posted July 1, 2012 if you can see the top of it, directly onfront of the shifter, a 4 sp has a cover plate that bolts on the top of the housing with 4-5 bolts. Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 1, 2012 Share Posted July 1, 2012 That is the easiest way: 4 speeds have that stamped sheetmetal cover forward of the shifter...5speeds don't. Quote Link to comment Share on other sites More sharing options...
clutchdust Posted July 1, 2012 Share Posted July 1, 2012 If you can't actually get to the cover plate, there is a "hump" in the casting for the extra gear on the 5-speed. Think it's on the PS if I'm not mistaken. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 1, 2012 Share Posted July 1, 2012 4 spd Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted July 2, 2012 Author Share Posted July 2, 2012 Perfect! Thanks a lot guys Quote Link to comment Share on other sites More sharing options...
