PETEW Posted December 23, 2001 Share Posted December 23, 2001 I know no one is producing motor mounts for Ford motors, yet. I am going back and forth between a turbo 6 from a 280ZX and a 302 mustang motor. There is a guy locally who has a '85 302 with the 5 speed for $600. The engine was rebuilt recently and was in a car until 4 months ago. I would go the Ford route but lack of a mounting system has me a little worried. I am trying to make a car the will autocross nicely and be decent in the drags, as well. 302 seems like an obvious choice to me but after doing a search and hearing about how much work it takes and there being no set instructions or mounts I may have to pass the engine up. Let me know what you guys think. Is the Ford conversion really that hard, or is it being blown out of proportion. Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
Guest scca Posted December 23, 2001 Share Posted December 23, 2001 its not THAT hard. just time consuming. i have tons of pics online. basically comes down to mounts and installing a heim in to the steering the rest is easy. Quote Link to comment Share on other sites More sharing options...
PETEW Posted December 24, 2001 Author Share Posted December 24, 2001 Thanks for the reply SCCA. I have been on your site a few times. I like the look of the mounts, but I wish I could find some drawings. If I had them, I could take them to a metal fabricator, and get the job done right. I figure this '85 motor will be a good start since it is the roller design with ease of 4 bbl carb. I like injection but just more to do. I've been through the search area a bunch of times for mount pictures. I like the fact the motor is so light and will make a balanced car. If any one has drawings of the mount system they used I would love a copy. My dream is to make a car that can autocross all day then go to the drags at night and do a high 12 low 13 time. Thanks again. Pete Quote Link to comment Share on other sites More sharing options...
Dave Posted December 24, 2001 Share Posted December 24, 2001 Hey PETEW fire me back a E-mail I have some pictures and the plans to build the mounts. Your E-mail address bounces. Dave...V8-240Z@juno.com Quote Link to comment Share on other sites More sharing options...
Guest jens Posted December 24, 2001 Share Posted December 24, 2001 Here is a link to a drawing http://zcar.netdojo.com/pics/motormountdrawing.jpg Is the mounts you are talking about different. If they are a bolt on to the stock datsun mounting places im interested too. Quote Link to comment Share on other sites More sharing options...
pparaska Posted December 25, 2001 Share Posted December 25, 2001 Jens, thanks for posting that - looks like FAQ material. Can you email jeromio about that? Cheers, Quote Link to comment Share on other sites More sharing options...
Guest scca Posted December 25, 2001 Share Posted December 25, 2001 isnt that ALSILs mounts?????? Quote Link to comment Share on other sites More sharing options...
Guest jens Posted December 26, 2001 Share Posted December 26, 2001 Yes it is. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2001 Share Posted December 27, 2001 I was able to use alsil's mounts with a 1991 302. I used the 1969 Mustang coupe (bolt-through) engine mounts ($57 Canadian) plus Flowtech "street rod"ceramic coated headers PART # 32000 ($330C Lordco). This worked well. My only caution is to wait to drill the actual holes in the mount you are fabricating (the holes that the bolt goes through that bolts the fabricated mount to the Ford mount...clear?) because for some reason mine was about 20 thou different that alsils...I also had to grind the fabricated mount a bit for header clearance. No biggie.We only had to put the engine/tranny in and out twice to get everything to work - see if you can beat that! Quote Link to comment Share on other sites More sharing options...
alsil Posted December 27, 2001 Share Posted December 27, 2001 Yup, that's mine. I got an email last night baou it. There are 2 revisions to the mounts- 1- adding a bottom part to the mount, making the part that slips over the frame a "C", so the bolt goes through the mount, frame, then the mount again, to resist motion and sagging. 2- move the actual mount holes (the tubes the motor mount bolts go through) out 1/8" for each. This makes the mount more rigid. I am thinking about doing a redesign with a tube, that would drop into place, ala the Focus 5.0 mount (they stole my idea, dammit!) So far, even without the reinforcements, it's worked great. I just am not satisified with the placement completely, and I want the engine a little bit higher. Other than that, I'm having a great time with the car now, since I have got past all the engine problems (take my advice, NEW is the way to go. Also, don't take ANYBODY'S word for it. Chekc stuff yourself!). Al Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2001 Share Posted December 27, 2001 I also used Alsil's mount design, though along with extending the reach buy 1/8" I lowered the engine an additional 3/8". I also sleeved the frame with 3/4" x @.125 tube rather than build a "C" config. Much thanks to Al for putting this on paper. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 29, 2001 Share Posted December 29, 2001 Ditto, Al - it made things go much more smoothly for those following in your steps. Scca has also been invaluable help to me. It's coming together nicely! Quote Link to comment Share on other sites More sharing options...
Guest 327zxer Posted November 3, 2002 Share Posted November 3, 2002 Would a 351w mount the same as a 302 Quote Link to comment Share on other sites More sharing options...
Guest 327zxer Posted November 3, 2002 Share Posted November 3, 2002 If the 351w mounts the same where can i find those Alsis-mounts and for how much. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 3, 2002 Share Posted November 3, 2002 I have a 1980 280ZX and am planning to transplant a 289 and C4 auto trans. from my 1970 ford van. can anyone give me any info on what kind of mounting system will work for me? hopefully the stock exhaust manifolds will work, I guess it will all be a trial and error thing... Quote Link to comment Share on other sites More sharing options...
