Guest scca Posted June 25, 2001 Share Posted June 25, 2001 pics up of the rad mount, black magic fan, painted engine bay, exhaust, sebring muffler and steering coupler with heim joint. should have the final pics up tomorrow.... its driveable now.. http://www.fonebooth.com/convt5Linstall.html Quote Link to comment Share on other sites More sharing options...
Guest scca Posted July 28, 2001 Share Posted July 28, 2001 loaded about 10 more pics up this am.... Quote Link to comment Share on other sites More sharing options...
jeromio Posted July 28, 2001 Share Posted July 28, 2001 Looks nice. The hood clears that huge intake plenum, eh? That thing makes it seem like the engine is sitting up much higher than it probably is. How much clearance do you have between the oil pan and the XMember? Quote Link to comment Share on other sites More sharing options...
Guest scca Posted July 28, 2001 Share Posted July 28, 2001 oil pan front drain bolt to x-member 1mm!! i will eventually notch the x-member or remove the drain plug there and relocate it to the bottom or the side of the front sump. the motor can actually get raised up about 1" i wanted as low and as far back as possible.. i almost went to far - hooking up the heater core was only a 3" hose from the 5L to the nissan core! tough to get on to say the least. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted July 29, 2001 Share Posted July 29, 2001 Is three inches enough to allow for some engine rocking? Also, did you use a restrictor in the heater hose like Ford did in the FOX cars? You might want to consider it as the FOX cars with 5.0s blew heater cores on a fairly regular basis with it and WAY more often without. It looks like a pipe plug with a small hole on it in the inlet hose. At leas the Z has an easier to remove core! Quote Link to comment Share on other sites More sharing options...
DavyZ Posted July 29, 2001 Share Posted July 29, 2001 Very cool Mike. I like the looks of your fabrication, especially the engine and radiator mounts. Very sano. Davy Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted July 29, 2001 Share Posted July 29, 2001 Coming along nicely Mike. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted July 30, 2001 Share Posted July 30, 2001 Heh, and he did it in like 2 weeks too I think! Gathered the parts and then had at it - wow! Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 30, 2001 Share Posted July 30, 2001 Mike looks nice - I was glad as scrolled down and saw you painted the bay later after trial fit . Thanks for documenting the swap! Quote Link to comment Share on other sites More sharing options...
Guest mtj71Z Posted July 30, 2001 Share Posted July 30, 2001 nice 300zx wheels too Quote Link to comment Share on other sites More sharing options...
Guest scca Posted July 30, 2001 Share Posted July 30, 2001 more new pics.... scroll to the bottom... i will slowly get them in separate sections... some top up pics that i've been asked for before and the engine bay finished.. all but i need a air cleaner????? what to do there... need some 3.5" mandrel bend then powdercoated and....a KNfilter in the hood hinge area.. Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 30, 2001 Share Posted July 30, 2001 SHWEAT! That thing looks great! I bet the Mustang in the background is jealous Quote Link to comment Share on other sites More sharing options...
Guest 327zxer Posted November 3, 2002 Share Posted November 3, 2002 Pics don't work Quote Link to comment Share on other sites More sharing options...
Guest scca Posted November 4, 2002 Share Posted November 4, 2002 http://fonebooth.com/convt5linstall.html this works?? just tried it but clicking on the top link doesnt now? Quote Link to comment Share on other sites More sharing options...
Guest scca Posted November 4, 2002 Share Posted November 4, 2002 how bizarre i didnt know that webpages are cap sensitive now? the L in 5L needs to be 5l must be my isp changed something as i know they keep changing up for more security, the link used to work but check the one i just posted - the link never moved but the server must have changed Quote Link to comment Share on other sites More sharing options...
blueovalz Posted November 4, 2002 Share Posted November 4, 2002 Nice to see some pics of your SBF install. Great looking project! Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 9, 2002 Share Posted November 9, 2002 Very nice ride! I really like the paint choice. Mike Quote Link to comment Share on other sites More sharing options...
Guest scca Posted November 9, 2002 Share Posted November 9, 2002 thats Maserati yellow from a 2000 - pricey paint!only European paint makers could make it - dupont and such couldnt even mix it from the code...only comes base clear.. that was my first try at base/clear on the engine bay- (i didnt paint the outside!) Quote Link to comment Share on other sites More sharing options...
