BloodOnTheApex Posted July 28, 2012 Share Posted July 28, 2012 Did a bit of searching. Out of what I saw, didn't really find anything I liked. I'm wondering if there are any differences in runner size between the L24e, L28e, and L28et intake manifolds. Does one flow better than the other? Should I get my L24e intake gasket matched or get a intake manifold from a 2.8 and do the same thing. I don't want to go aftermarket (Don't even know if there's aftermarket EFI intakes?), looking to spend the least amount of money. As usual. Application is make-shift turbo set up. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 28, 2012 Share Posted July 28, 2012 This thread is informative - http://forums.hybridz.org/index.php/topic/95316-braaps-l6-efi-induction-advice-and-tips/ Post #3 is intake, but the rest is definitely worth reading also. Quote Link to comment Share on other sites More sharing options...
ctc Posted July 28, 2012 Share Posted July 28, 2012 BRAPP did write-up on the L28E vs L28ET. General conclusion was L28ET was slightly larger diameter runners. 1 to 3 mm if I remember correctly. Runners are the restriction for these manifolds not the throttle body. There is some benefit to having a step between the manifold and head as long as the head is larger diameter, but search to find it. There are some pretty big turbo numbers out there on ported stock intakes, but most involved splitting th intake, porting it and welding back together. For your "make shift" setup, stock or hand ported intake (of whatever flavor you have) should handle your needs without spending a lot of time chasing that last 3% of Hp. Quote Link to comment Share on other sites More sharing options...
BloodOnTheApex Posted July 28, 2012 Author Share Posted July 28, 2012 Thanks for the answers guys. Was searching intake specific, should have searched for more general differences. Not really chasing any power. Didn't want to create a big restriction if the NA manifold runners were much smaller than the T manifold. I knew the runners were restricting on these, but I don't think it's going to make much of a difference at 5 pounds or so. Not really building this for the power numbers, just for fun. haha. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted July 28, 2012 Share Posted July 28, 2012 If you're on the stock turbo, don't worry about it. I have a stock n42 intake on my l28et, last night I went 12.6 at 108mph in the 1/4 with it, the rest is a very mild build IC, exhaust, megasquirt, fuel system. Quote Link to comment Share on other sites More sharing options...
