Wiring help
I Have a problem with a couple wires that I dont know where they go. There is a black wire coming off a resistor next to the ignition coil that has been chewed up and I dont know where it goes. Also there is a female bullet style connector that does not have its counterpart. I was hoping you guys could help me figure this out.
That's a capacitor aka condenser, not a resistor. One end is hot (probably when the key is on), the other end goes to ground.
No help on the female bullet. Floating in space like that it could connect to anything. Might be for the capacitor.
Well the blue wire on the capaciter goes into the wiring harness. Im guessing black is ground. There is a chewed up ground wire by the distributor. I'll solder some wire and put a bolt connector on the end.
Anyone else know about the bullet connector wire?
