Header Bolt minus 1
steve260z
Well, after putting my stroker together and getting the motor in the car, I just noticed one header bolt is broken off in the head. (Machine shop missed this as well)
Its the very 1st hole in the head. If I make sure the header flange is perfectly flat and do not use this 1st bolt hole will I have a leak????? Crap......
Thanks
steve
I had that problem and fixed it with a hand drill and harbor freight stud extractor. You might be surprised, you might be able to spin it out with with friction and a drill bit in reverse. Won't hurt to try, just be careful.
