77 280z Trouble Accelerating
Just bought a stock 77 280z..
It is missing quite a bit of power compared to my 76 with tripple webers.
I just cleaned the tank, installed new fuel pump, replaced a clogged injector with a working injector i had lying around. Checked timing plugs and wires everything looks good there.
So no onto the problem...
The car cruises beautifully but when i try to accelerate it wont go past about 3000 rpms. i can go past 3000 if i just ease into it but not full throttle. Sounds to me like enrichment is not kicking in?
Any ideas on what i should be looking at?
ok so i got the car to run decently (revs past 2000-3000 rpms)
what i did:
I removed engine bay filter
sprayed compressed air through the fuel rail/return line
disconnected fuel pump and sprayed air through supply line
connected everything with a fuel pressure gauge between filter and fuel rail
Pressure at idle and revving is 29 psi
I then removed the vacuum line to the FPR and my fuel pressure went to 38
i took it for a spin and 1st gear revs fine to about 5000 or so then feels like it looses some get up
2nd gear revs a little slower and 3rd is even slower than 2nd.
not sure how a stock 280z drives but my 280z with the tripple webers seems to have a little more pickup especially on top end
Is the FPR bad?
What other things should i look at?
BTW i dont think this car has a CHTS
well got the car running great and i had done the 280zx alternator swap/mod
problem...
i was driving the car and got stuck in traffic the temp gauge started to climb to a little bit past halfway but continued to run and idle fine. I then took a right and gave it some gas in first.
next thing i know i hear a pop and the car dies and smoke comes in by the fuse box. i stop the car and start to see smoke out the hood so i pop the hood to see the wiring harness on fire. I grabbed my bottle of water and a wrench and put out the fire and pulled the positive battery terminal.
I just finished rewiring a small section of the harness
this includes:
ground to the side of the block all alternator connections(wired the S-yellow wire straight to battery terminal to get a good sense) and power wire that splits into 3 coming off of the alternator for charging.
I did not have a fusible link for the alternator which is why i had the fire (lesson learned the hard way). So everything is wired back up and i have a fusible link in place. So i start the car and start trouble shooting.
Voltage at the battery is a steady 14.00 volts.
The fusible link for the alternator starts getting really hot so i shut the car off (this is why i had a straight wire in the first place).
What would be causing the fusible link to get hot? Why would there have been so much current to start a fire in the first place?
