daddydonuts Posted August 21, 2012 Share Posted August 21, 2012 My tranny grinds when trying to shift the transmission into reverse, all other gears shift smoothly. Is this an easy fix or is the tranny on its last leg? Quote Link to comment Share on other sites More sharing options...
Leon Posted August 21, 2012 Share Posted August 21, 2012 (edited) Sounds normal to me, depending on the severity of the "grind". Reverse does not have a syncro. Hold the clutch longer before putting it in reverse or shift into another gear before reverse. Both methods slow the countershaft down so that the spur gear can engage smoother. Edited August 21, 2012 by Leon Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted August 21, 2012 Share Posted August 21, 2012 1. Shift it into fourth 2. Drop the clutch slightly. 3. Clutch back in. 4. Proceed to now put the car into reverse. It'll drop in every time. Like Leon says, reverse has no syncro so sometimes it takes a little coaxing. Quote Link to comment Share on other sites More sharing options...
Zmanco Posted August 21, 2012 Share Posted August 21, 2012 1. Shift it into fourth 2. Drop the clutch slightly. 3. Clutch back in. 4. Proceed to now put the car into reverse. It'll drop in every time. Unless the clutch isn't fully disengaging ... Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted August 22, 2012 Author Share Posted August 22, 2012 Did the 4th gear drop and it went into reverse "better". I think Zmanco is correct about the clutch not disengaging. I just put the engine and transmission in a couple months ago and have not really driven it yet. I will adjust the slave cylinder and clutch pedal next. Quote Link to comment Share on other sites More sharing options...
Leon Posted August 22, 2012 Share Posted August 22, 2012 Bleed first, make sure all the air is out before trying to adjust. Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted August 23, 2012 Author Share Posted August 23, 2012 Bleed first, make sure all the air is out before trying to adjust. Thanks Quote Link to comment Share on other sites More sharing options...
