280z4me2 Posted August 22, 2012 Share Posted August 22, 2012 Been reading of trouble with block buggers due to angle plugs. Will the stock camaro headers clear in an s30? Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 22, 2012 Share Posted August 22, 2012 replied to your post about the oil pan. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted August 22, 2012 Author Share Posted August 22, 2012 This is a some what budget build so If I can get away with some used 350 block huggers I may do that. I have read people are using regular block huggers on the LT1 even though the heads are D-Port and it hasnt caused a problem for them. Anyone here ever use a specific brand of block huggers other than JTR and got way with clearance? Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 23, 2012 Share Posted August 23, 2012 What is hard is getting the angle plug ones that won't leak. Thats why we sujest the JTR ones. Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 23, 2012 Share Posted August 23, 2012 I'm running ceramic coated Patriot block huggers on my LT1 with no clearance problems. Quote Link to comment Share on other sites More sharing options...
mark Posted August 24, 2012 Share Posted August 24, 2012 I'm using hooker blOck huggers on mine. No problems. Been on the car for 18 years Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 24, 2012 Share Posted August 24, 2012 Are you guys using the jtr mounts or the scarab/msa ones? Quote Link to comment Share on other sites More sharing options...
wheelman Posted August 29, 2012 Share Posted August 29, 2012 (edited) I'm running the Hedman Tight Tubes on iron LT1 heads (not angle plug) with no problems except access to a couple of the plugs for removal is tight. These headers provide a lot of clearance to the frame rail on the right and the steering shaft. Edit: Running JTR mounts. Edited August 29, 2012 by wheelman Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 29, 2012 Share Posted August 29, 2012 On 8/24/2012 at 3:17 PM, GOTHALOSISM said: Are you guys using the jtr mounts or the scarab/msa ones? JTR mounts on mine. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 30, 2012 Share Posted August 30, 2012 Huh had I known that I probably would have gone that route instead. As luck would have it though I have had no issues what so ever with my JTR headers. Quote Link to comment Share on other sites More sharing options...
