Quick question on rod/ piston fitment (L24/RB)
Kash
Will the L24 rods fit the RB26dett pistons with no modification? Per the engine calculator, the piston end bores are the same (21) but the piston end thicknesses are different between the L24 rods (25.4) and the RB rods (21.8). Not certain what the piston end thickness is…is this the piston clearance needed to fit the rods? If so, I will assume that the L24 rods would not fit the RB26 pistons. Can anyone confirm or deny?
Lost my oversized (89mm) block to cracks so now I need a set of 86mm turbo pistons to reassemble with my LD28 crank and stock block...the OEM turbo pistons won't work, they will be protruding 2mm above deck with the stroker crank. If this is a go I will be needing a set of used OEM RB26 turbo pistons, if anyone has a set for sale or can send me one for testing, I would apreciate (I will pay for shipping both ways).
Thanks.
