DIY LED turn signal indicators
SUNNY Z
Ever since I swapped to autometer gauges, I had no turn signal indicators. This is a quick, CHEAP, and easy way to get some.
I took the piece off the top of the column, after I marked it with a sharpie where I wanted the LED's.
Then I drilled out the holes, and used a plastic weld 2 part epoxy to mount the LED's flush with the surface. You need to use a resistor on the + side of the LED, i believe i used 1/2 w 1K Ohm
Next I soldered wires onto the contacts of the switch
Topped it off with spade connectors (idiot proof) . (I later insulated over the spades)
and the finished product. IDK what happened when i uploaded the vid from my phone, but you get the idea.
Edited by SUNNY Z
I found an old Ford truck with the column mounted PRNDL indicator and painted the clear plastic black and mounted 2 green and 1 blue 12V led bulbs and wired them to the existing wiring. I ground down the unit to match the steering column cover and used black double stick tape to keep it in place.
