sidewaz Posted September 12, 2012 Share Posted September 12, 2012 Just wondering if there is a pedal setup you can buy for the electronic throttle body or is everybody changing to cable. Quote Link to comment Share on other sites More sharing options...
rags Posted September 12, 2012 Share Posted September 12, 2012 We just did an LS2 swap from a GTO and used the GTO pedal. Very simple installation. All we did was bolt a plate to the firewall at the stock pedal location and then bolt the GTO pedal to that plate. Took about a half hour. Joe Quote Link to comment Share on other sites More sharing options...
m1noel Posted September 12, 2012 Share Posted September 12, 2012 Ditto Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 12, 2012 Share Posted September 12, 2012 It took me longer than that but everything does. I marked the location and height of the stock pedal on the tunnel. Then I cut the pedal bracket off the gto pedal assembly. I needed a spacer made of wood to get pedal in proper location and angle. Screwed block to stock bracket on firewall and pedal bracket to block. I used a 6-pin weather pack connector on the firewall side so that it will be easy to detach engine harness from the pedal. Works great feels really normal. Instant response. Be sure the pedal bottoms onto the stock pedal stop since the bracket is plastic. My harness guy marked the wires for me. Since I had such a cool looking gas pedal, I trimmed the brake and clutch pedal so the gto pads fit. Quote Link to comment Share on other sites More sharing options...
