280z4me2 Posted September 12, 2012 Share Posted September 12, 2012 Can someone direct me to the motor mounts I need for a 350 swap? Quote Link to comment Share on other sites More sharing options...
traeg Posted September 12, 2012 Share Posted September 12, 2012 http://forums.hybridz.org/index.php/topic/108405-s30-v8-conversion-parts-sbc-jtr-with-headers/ here is you a complete swap for your can and it is a damn good kit. same one I have Quote Link to comment Share on other sites More sharing options...
deja Posted September 12, 2012 Share Posted September 12, 2012 http://forums.hybridz.org/index.php/topic/108405-s30-v8-conversion-parts-sbc-jtr-with-headers/ here is you a complete swap for your can and it is a damn good kit. same one I have That is a good deal but remember the LT1 uses different headers than an old school SBC. LT1 has angled plugs and "D" ports. JTR also sells Sandersons for the LT1. Motor mounts and setbacks are the same. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted September 13, 2012 Author Share Posted September 13, 2012 I already purchased the Sanderson D port headers. motor is ready to go in minus the engine mounts. I plan on making the set back plates. Quote Link to comment Share on other sites More sharing options...
deja Posted September 13, 2012 Share Posted September 13, 2012 I already purchased the Sanderson D port headers. motor is ready to go in minus the engine mounts. I plan on making the set back plates. You can buy just the spacers from JTR for $20 and $25. IIRC the motor mounts are from a 1985 chevy but the JTR manual will tell you for sure. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 15, 2012 Share Posted September 15, 2012 Yup the rubber mounts are from a 85 chevy truck Quote Link to comment Share on other sites More sharing options...
rsicard Posted September 16, 2012 Share Posted September 16, 2012 The equivalent to the rubber chevy truck mounts are the PROTHANE 7-509-BL(ack) mounts that can be ordered from Summit Racing. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted September 17, 2012 Author Share Posted September 17, 2012 I plan to make the set back plates and spacers. How detailed are the spacer widths in design? Should they be exact to JTR spacer width or as close as possible while stalacking up 1/4 and 1/8" plates? Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 18, 2012 Share Posted September 18, 2012 With my LT1 swap I had a friend make them with a CNC machine, they look nothing like the JTR ones but work beautifully. Mine actually sits a little lower in the bay since I am not using some of the spacers. The alignment with the rear end is dead on as well. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted September 18, 2012 Author Share Posted September 18, 2012 (edited) How do you meassure to know its dead on? And why is one side so much thicker than the other? Edited September 18, 2012 by 280z4me2 Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 18, 2012 Share Posted September 18, 2012 I had the DS shop use a laser to make sure it was correct. If I use the extra spacers it angles the rear of the engine down towards the ground. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted September 25, 2012 Author Share Posted September 25, 2012 Why are the spacers different thickness for each side according to JTR? Seems like the motor would lean sideways if I am thinking correctly. Anyway you could measure the thickness of your spacers on each side for others to use as a template? Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 25, 2012 Share Posted September 25, 2012 Yeah I have to dig through my pile of parts to see if I even still have them. Quote Link to comment Share on other sites More sharing options...
wheelman Posted September 29, 2012 Share Posted September 29, 2012 Why are the spacers different thickness for each side according to JTR? Seems like the motor would lean sideways if I am thinking correctly. Anyway you could measure the thickness of your spacers on each side for others to use as a template? They're different thickness to offset the motor to right side of the car a bit, it provides clearance between the left header and the steering shaft. The set back plates are shaped accordingly so that the engine is not tipped to the right or left. Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted September 30, 2012 Author Share Posted September 30, 2012 Exactly what I needed. Thanks! Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 30, 2012 Share Posted September 30, 2012 with out using those extra spacers I have about 1/2" - 3/4" seperation from my headers and steering shaft. Sorry about the wires in the way, I was still in the process of putting in the engine when I took the pic Quote Link to comment Share on other sites More sharing options...
280z4me2 Posted October 2, 2012 Author Share Posted October 2, 2012 Would you happen to know the total thickness of your spacers? Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted October 2, 2012 Share Posted October 2, 2012 I'll see if I still have them laying around, doubtfull but possible. Quote Link to comment Share on other sites More sharing options...
NCchris Posted October 2, 2012 Share Posted October 2, 2012 Guys not intended as a hijack but toward the bottom of this link I have some pictures of the JTR mounts mocked up on a front crossmember. chris Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 25, 2012 Share Posted October 25, 2012 Guys not intended as a hijack but... chris LOL, thanks for posting that, Chris. I like the aluminum set back plates. Mine are steel, but I don't care at this point since they get the job done. Davy Quote Link to comment Share on other sites More sharing options...
