cws1807 Posted October 6, 2012 Share Posted October 6, 2012 '82 turbo dizzy MSII controlling fuel and spark (3.2.1 release firmware) Trying to get my car started on MSII, it will fire and run for about 2 seconds then dies. But I have not gotten TunerStudio to sync with ecu at all. I haven't been able to find anyone's ignition settings for the latest release of firmware (3.2.1) but I here is what I have it set as now. Spark mode: Basic trigger Trigger Angle/Offset: 60 Skip pulses: 3 Ignition Input Capture: Rising Edge Spark Output: Going High (Inverted) Number of coils: Single Spark A output pin: JS10 I'm guessing that because the ecu is not synced it is cutting spark or fuel after just a couple of seconds, any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
motomanmike Posted October 6, 2012 Share Posted October 6, 2012 Do you have a stim? Quote Link to comment Share on other sites More sharing options...
cws1807 Posted October 7, 2012 Author Share Posted October 7, 2012 Yes I do and when the RPM switch on the stim is set to NPN the ecu is synced and operates perfectly, however with the switch on PNP I get nothing at all. Quote Link to comment Share on other sites More sharing options...
cws1807 Posted October 8, 2012 Author Share Posted October 8, 2012 I've confirmed that the wiring to my dizzy is correct and I am getting a signal from it, but could I have a bad dizzy that's giving an incorrect or intermittent signal that's causing the sync errors? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 8, 2012 Share Posted October 8, 2012 I've confirmed that the wiring to my dizzy is correct and I am getting a signal from it, but could I have a bad dizzy that's giving an incorrect or intermittent signal that's causing the sync errors? It sure can; try capturing the sync errors in a tooth log. Quote Link to comment Share on other sites More sharing options...
cws1807 Posted October 9, 2012 Author Share Posted October 9, 2012 Here's what I get using the composite logger. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 9, 2012 Share Posted October 9, 2012 It would be better if you could attach the whole file. Quote Link to comment Share on other sites More sharing options...
cws1807 Posted October 9, 2012 Author Share Posted October 9, 2012 Ok no problem here is a zip file with my msq and logger files. CurrentTune.zip Quote Link to comment Share on other sites More sharing options...
