RaceDriver Posted November 4, 2012 Share Posted November 4, 2012 (edited) We've created a page with dimensions and part numbers for the most common GM LS-series oil pans as a resource for anyone doing a swap. We will continue to update the page with the latest part numbers and additional pans. Link: http://www.improvedracing.com/LS-oil-pan-dimensions.php If anyone thinks there's something we should add, let me know! Edited November 5, 2012 by RaceDriver Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 16, 2012 Share Posted November 16, 2012 Thanks, just picked up a L76 6 liter, do not think the original pan on the G8 will work...crap! Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 26, 2012 Share Posted November 26, 2012 What oil pan are you folks running on your set ups, I would love to be able to keep the Pontiac G8 pan as it hold "8" quarts! Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 27, 2012 Share Posted November 27, 2012 Unless you are using nitro, does it really matter how many quarts the oil pan holds? I've been using Mobil1 synthetic in my LS2 and that stuff costs like gold! This is an honest question, not a smart alek remark. I'm using a stock Camaro pan. It hangs an inch too low, so I put a 1" bar on my crossmember to break bottles or any other trash in the road before hitting the aluminum oil pan. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 27, 2012 Share Posted November 27, 2012 6 quarts is fine really, I just like the G8 pan. Good idea for road crap elinination...LOL I really like the idea, sorry little critters! Quote Link to comment Share on other sites More sharing options...
mattd428 Posted November 28, 2012 Share Posted November 28, 2012 what about the c5 oil pan bat wing style? Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 28, 2012 Share Posted November 28, 2012 I was thinking along those lines but worry that it may interfer with a set of long tubes? My long tubes on my first gen sbc are real tight with the stock style oil pan. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted December 1, 2012 Share Posted December 1, 2012 im using a c5 pan long tubes should fit Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted December 2, 2012 Share Posted December 2, 2012 How does that C5 pan fall relative to the bottom of the front crossmember? Using JCI mounts? Quote Link to comment Share on other sites More sharing options...
mattd428 Posted December 4, 2012 Share Posted December 4, 2012 didnt use jci mounts i welded in my own ill get you some pics later on tonight. but i dont think jci mounts would be a problem i have alot of room. Quote Link to comment Share on other sites More sharing options...
240z72 Posted December 5, 2012 Share Posted December 5, 2012 That C6 pan looks very tempting to use for LS Z swap. As it is about an inch shorter then the camaro pan which I currently have. It has the same part number for the gasket so im guessing it will fit the ls1. If anybody has info on this let me know. Im going to run this by LS1TECH also. I need the clearance!! --Jim Quote Link to comment Share on other sites More sharing options...
240z72 Posted December 6, 2012 Share Posted December 6, 2012 Talked with some people and it seem for the best pan clearance. It looks like the Corvette C6 pan is it. Just swap the pan and pickup. May have to mod the dip stick though. Sorry if im thread jacking just thought this could help. Jim Quote Link to comment Share on other sites More sharing options...
RaceDriver Posted January 15, 2013 Author Share Posted January 15, 2013 The reason to run the 8 quart Camaro/G8 pan is because the extra capacity helps prevent oil starvation. If you won't track or race the car at all, this is not a concern. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted January 15, 2013 Share Posted January 15, 2013 I am having a 3/16" thick, 1.5" tall wedge-shaped "cattle catcher" welded onto the bottom of my front crossmember in order to deflect any rocks or beer bottles that I may encounter in the road or on the track. I already have a few marks on my LS1 Camaro oilpan, which hangs 1/5" below the crossmember with the JCI mount system. Luckily none of the impacts have been of sufficient force to cause a breakage. Quote Link to comment Share on other sites More sharing options...
alainburon Posted January 16, 2013 Share Posted January 16, 2013 Talked with some people and it seem for the best pan clearance. It looks like the Corvette C6 pan is it. Just swap the pan and pickup. May have to mod the dip stick though. Sorry if im thread jacking just thought this could help. Jim Do you know if anyone is using the C6 oil pan on a S30 with long tubes? Just want to make sure it fits. Quote Link to comment Share on other sites More sharing options...
