1jz Driveshaft Length
ineedboost
I searched a bit but couldn't find an answer. Can anyone with a 1jz/2jz swap tell me how long your driveshaft is, and what transmission you're using? I have a sbc in my Z, but I may swap to a 1jz and I want to know if I can reuse the driveshaft I already had made(with some modifications obviously). Thanks
  • 5 weeks later...
The measurement will be different depending on how you do your motor mounts. My measurements are 28 inches from tailshaft to diff flange. I took that measurement to the driveshaft shop and they made mine for 215.00 with a new Toyota yoke.
No just get the motor and trans mounted to your mounts and take the measurement from the end of the tail shaft to the diff flange and tell your driveshaft shop the measurement. They do this all the time. It's not a big deal. No special tools just a tape measure.
