Question about the fusible link upgrade
Someone pointed out to me recently that one of my fuse blocks had been cut out, and the remaining wires wire-nutted together. And the other fuse block had wires connecting the terminals, as opposed to fusible links.
So, I wired in the distribution block. On my car, it's (the installation guide online, I think it's on atlanticz) showing 3 of the wires get a 50a fuse, and one gets an 80a (for a 77 model year, which mine is). So, it didn't matter which wire went where in the block as long as the wire needing the 80a had an 80a fuse.
Checked out a wiring diagram online. It appears that three of the wires go to the same plug, while one of them goes to the alternator. Makes sense this would be my 80a (I tried searching this but was surprised not to find anything that explained differentiating these 4 wires. I know I saw it somewhere...). So, I checked for continuity between the alt plug and each of my 4 wires at the fuse block. Found one wire with continuity, so I stuck the 80a there, and the remaining 3 slots got the 50a's.
I also put in a key switch (from Black Dragon) between the starter and the pos terminal on the battery. After I get the car back together (painting and pretty thorough budget frame-off), I'm gonna wire the stereo and fans straight to the battery with an inline fuse (and toggle switches for the eng fan and ac fan). I figure that way I won't lose my stations if I take the battery key out. And later, I'd like to get the megasquirt to control the engine fan, but I'm putting it off at the moment bc of time constraints (moving in...2 weeks?). And the fans will all get their own relay.
My question is....Does all that sound right? I've been looking at this car for 6 months and I feel like Jack Torrance in The Shining.
So, does all that sound logical and won't immediately burst my car into flames?
