patty Posted December 28, 2012 Share Posted December 28, 2012 The ones I want have 6 bolts at the stub axle end. One axle is longer than the other. Good boots preferred but not mandatory Also - looking for the r200 snap in 4 bolt stub - that the u jpoint style half shaft will bolt to. Thanks Quote Link to comment Share on other sites More sharing options...
MarkM Posted December 29, 2012 Share Posted December 29, 2012 I have a set of 280 stubs. PM'd you. Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 29, 2012 Share Posted December 29, 2012 The ones I want have 6 bolts at the stub axle end. One axle is longer than the other. Good boots preferred but not mandatory Also - looking for the r200 snap in 4 bolt stub - that the u jpoint style half shaft will bolt to. Thanks The 6 bolt CV axles are actually NA axles. Even though some parts stores show them as turbo. Turbo axles are 4 bolt. If you change your title you'll probably get more looks. Quote Link to comment Share on other sites More sharing options...
Akira Posted December 29, 2012 Share Posted December 29, 2012 The 6 bolt CV axles are actually NA axles. Even though some parts stores show them as turbo. Turbo axles are 4 bolt. If you change your title you'll probably get more looks. The 300zx turbo axles are 4 bolt. The 280zx turbo axles are 6 bolts as I just removed them from my stock 81 280zxt a few months ago. Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 29, 2012 Share Posted December 29, 2012 (edited) My mistake. I think that for the 280ZX the axles are the same for turbo and NA, that's what was in my mind. The parts store will sell you the same axle for NA or turbo applications. I haven't figured out what the difference is. Edit - Actually, I think that only the 280ZX turbo cars were intended to have CV axles, the NA's had u-joint half-shafts. But, apparently, in 83, Nissan put CV's on some of the NA cars. So, in short, any 280ZX CV axle will be the short 6 bolt axle that the OP is looking for. I have a set of 6 bolt CV axles from an NA car in my garage. Sorry to muddy things up. Edited December 29, 2012 by NewZed Quote Link to comment Share on other sites More sharing options...
patty Posted January 4, 2013 Author Share Posted January 4, 2013 I found some - thanks to those who replied. Quote Link to comment Share on other sites More sharing options...
