L6 Transmission ID
BlueStag
In less than 30 seconds I found 4 threads that accurately told how to ID the transmission. Yet here we are. What shall we discuss next? Differences between a 240 and 280? How to get more HP out of a L28?
My point would be "read".  Read Post #4 and Post #16 again.  And Post #1.
Why do you not have any? I have 5) 5-speeds. I keep an eye on the pull and save yard(s) up here. Everytime a Z comes in, I check to see if it has a 5 speed. If it does, I come back with a few basic tools as soon as I can, and 20 minutes, and $50 later, I have another one!
Fundamental indolence.
You found threads that will tell you what the ratios are of all the gears on a 5sp just by looking at the numbers cast on the trans and referencing a chart?
You have better skills at searching then, because I tried three or four combinations of search words before I started this thread.
Care to share the threads you found?
And the way to get more power out of a 280 is to slap a bigger turbo on it.
$50?
I only wish.    I was just at my local pick and pull.   They want $150.
For that money I would expect to buy one here and get a warranty of some sort.
