pasakZ Posted January 8, 2013 Share Posted January 8, 2013 I have used the search and read lots here and on zcar.com but still have questions. I am trying to do this conversion. I have modified maxima brackets and calipers/rotors from an 83 zxt -- replacing the drums on my 77 280. I can't seem to make them fit, when I read it seems some have done this with no problem, but when I try to mount the calipers there is not enough clearance. Do I need the calipers from an earlier model (79-81)? or calipers from a late model maxima (88 or so) or just a different rotor? -- I came by all the parts cheap and really only wanted the swap for easier maintainance but now I am into it and looking to continue as inexpensively as possible (with disc brakes) to get me back on the road. so with the maxima brackets what caliper/rotor combination fits on rear 280z? It seems others have made this combination work and I am trying to find out if I am just doing something stupid. Thanks Link to comment Share on other sites More sharing options...
duragg Posted January 8, 2013 Share Posted January 8, 2013 I would post some pics so the smart people can help. I got lucky with my 280ZX rear caliper / rotor / adapter. Found on Craigslist-bought cheap- perfect fit. Sorry... Link to comment Share on other sites More sharing options...
AZGhost623 Posted January 15, 2013 Share Posted January 15, 2013 (edited) Hmm, I did this swap back in December, and everything fit just right. My Calipers were off an 1986 Maxima, and 280ZX rotors. The caliper brackets can only really go on one way. Anyway, the hardest part for me was removing that dang dust shield off the drums. I F'd up on the removal, I should have not taken everything apart. I screwed up the spindle taking off the nut with an airgun. I was extremely lucky finding replacements. My only suggestion would be to cut the dust shield off, and dont take anything else off but the drums obviously.. Where did you get the new rear caliper brackets from? You can get some from here, might be able to find somewhere else cheaper. http://www.silverminemotors.com/Rear-Stage-4-Kit-Brackets-Rear-Stage-4-Kit-Brackets.htm http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=8 Oh and check this link, might be handy. http://forums.hybridz.org/topic/104113-silver-mine-motors-rear-disk-conversion-kit-write-up/ I have some pictures of my build, but not sure if they will help any.... Edited January 15, 2013 by AZGhost623 Link to comment Share on other sites More sharing options...
wesmc Posted February 2, 2013 Share Posted February 2, 2013 pasakZ- Did you ever figure this out? Link to comment Share on other sites More sharing options...
RebekahsZ Posted June 9, 2013 Share Posted June 9, 2013 What year and model rear rotor is used on the Desert Z (Sean Schlapi) maxima-caliper rear dic conversion? I need to buy a pair. Link to comment Share on other sites More sharing options...
Nisssmo510 Posted January 4, 2015 Share Posted January 4, 2015 pics please. I didn't have any issue with the vegas dude bracket. Link to comment Share on other sites More sharing options...
S30 SPL Posted February 24, 2015 Share Posted February 24, 2015 Are you guys making changes to your porportioning valve or master cylinder when going from drum to disc? Link to comment Share on other sites More sharing options...
Miles Posted February 25, 2015 Share Posted February 25, 2015 Are you guys making changes to your porportioning valve or master cylinder when going from drum to disc? Sometimes. There is no 'generalized" answer without knowing the specific brake configuration you are asking about. See Brake FAQs and the other posts in the brake section etc. Link to comment Share on other sites More sharing options...
S30 SPL Posted March 16, 2015 Share Posted March 16, 2015 I have a 77 280Z with the stock booster and master. In the front, I have converted to the Mustang Cobra 2 piston calipers (modern motorsports), in the rear, I have the 08- Mustang GT single piston calipers (silver mine motorsports), all vented disc. I haven't really put the car through it's paces so I'm not sure what will exactly happen. But if I need to change certain things, I'd rather do it now instead of later. Link to comment Share on other sites More sharing options...
jeremy101 Posted July 23, 2016 Share Posted July 23, 2016 I'm doing 240sx rear brakes upgrade with modern motor sport bracket . So does anyone know the size of bolts to use? info on brake lines size from 280z car to 240x caliper. Link to comment Share on other sites More sharing options...
