Ron240zxt Posted July 10, 2001 Share Posted July 10, 2001 Hello all again, How much flow can i get out of the factory turbo exhaust manifold before it starts restricting performance by causing back pressure. a: 300 hp b: 400hp c: 500hp This is what it comes down to. Will i be happy with the performance of a turbo header. or should i use the factory manifold. What are the advantages/disavantages between both set ups. thank you Ron Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted July 10, 2001 Share Posted July 10, 2001 I don't know the upper limit, where the stock manifold makes a serious impact on performance, but I saw a L28T yesterday rip low 12's on the stock manifold. I think that is close to 400 horsies in a 240Z. Of course, he's running the stock cam as well, but a 3" exhaust. If I were to try to make 500 hp, I'd go with a tubular exhaust manifold, but not for 400. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted July 10, 2001 Share Posted July 10, 2001 Ron, people are and have made 500hp with the stock exhaust manifold. However, I would do as much porting as you possible can to help flow. The inlets can be heavily ported, but the best area to hit is where cylinders 1-4 enter through 1 opening to the turbo area. If you stick your finger in there you will notice the top wall can have atleast 3/4" of material removed. Anyway, I don't think you will have a problem using it for your application. Hell, TimZ made 391hp&410ft-lbs @wheels with that manifold. However, a tubular exhaust manifold would probably net about 40hp on a big turbo application. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted July 11, 2001 Share Posted July 11, 2001 i am collecting parts to build up a turbo engine with more hp.has anyone sent an exhaust manifold to extrude hone?this gets places where you cant get grinder into. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted July 11, 2001 Share Posted July 11, 2001 Randy, Extrude Hone is pretty cool, and if you have the bucks for their services, I'm sure they can make a good thing better! The examples of what they can do for manifolds are really stunning. I suppose if I were putting together a 500hp Turbo Z I would look them up. Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 17, 2001 Share Posted July 17, 2001 Whatever type of exhaust manifold u chose,(standard or fabricated tubular) I strongly recomend getting it ceramiced coated(HPC)inside and out,and while you're there get the exhaust housing done as well--The last turbo exhaust manifold I built using cast steel welding bends I had it HPCed along with the exh housing , man what a differance way lower under bonnet temp's, and far less lag-------GOTTA DO IT Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted July 18, 2001 Share Posted July 18, 2001 hey turbo boy! Do you have pictures? Custom manifold is a dream, but im still curious have you had any cracking, or deformity problems with it? Evan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 18, 2001 Share Posted July 18, 2001 Evan, the manifold was'nt for a Zed,it was for my (dont laugh) turbocharged intercooled Mini circuit car, no warpage or cracking problems at all: the key to that is keeping the primary pipes seperate all the way too the turbo flange, and making both cyl head and turbo flanges out of at least 10mm thick plate , I used 10mm for head flange and 12mm for turbo ,try and stay away from "log" type manifolds where 2 or more exhaust pulses overlap, as this is where you get differing temps along the lenght of manifold,causing cracking/warping etc, also the ceramic coating on the inside of manifold reduces the amount of heat soaking into manifold therefore reducing these problems, as well as keeping exhaust gas hotter-the hotter the gas the faster it moves= less lag ........hope I hav'nt bored you. Quote Link to comment Share on other sites More sharing options...
