How does my timing chain look?
Ben's Z
This leads to something I had a question about anyhow.  In the "How to" book it talks about multiple bright links on the chain.  My new chain from Cloyes only has two... Also my slack side guide had no figure 8 or elongated hole on the bottom bolt hole.  Per Peter at PMC and Z Greek, I elongated this for adjustment purposes with a dremel and rotary rasp.  I will have to fool with getting the tensioner tighter this evening.  I guess I am confused as to why the tensioner needs to be fully compressed.
You can adjust if you'd like to have the tensioner flush with its housing. It is how it is suppose to be after install. To do so, you can play with chain guide position on top of the tensioner.
To check your chain, you should see if your sproket is timed correctly & if the guides are not worn out.
