wickiewicked240z Posted February 2, 2013 Share Posted February 2, 2013 Does anyone know the length of the linkage for the triple weber DCOE. There are 3 adjustable linkages. From center hole of one heim to the other. thank you Quote Link to comment Share on other sites More sharing options...
Tony D Posted February 2, 2013 Share Posted February 2, 2013 "All the same." Dependent on all arms in the same plane on the crossbar, and all carbs perfectly in-synch and flowing identically. The length is different depending on the top link. What is on my DCOE/FET manifold may not be what is on your DCOE/Cannon or someone else's DCOE/TWM setup. Quote Link to comment Share on other sites More sharing options...
wickiewicked240z Posted February 2, 2013 Author Share Posted February 2, 2013 I know everyones setup is different. Just wanted a general measurement since I'm making my own linkage. And needed to get the right length rod. Quote Link to comment Share on other sites More sharing options...
duragg Posted February 2, 2013 Share Posted February 2, 2013 Bout 3"? Perfect alignment, equal throw, positive return to stop, don't over-constrain the butterfly position adjuster (some refer to as idle speed screw). I designated one carb as master and the others as slave and just adjust the master. I can take close pix if u need. Would be TRICK to make it real easy to adjust each rod length without that silly jam-nut arrangement. Half mine are r/h thread, other is l/h thread and its just a g/r. Quote Link to comment Share on other sites More sharing options...
