zx performance brake pads??
shuttlefever
hey all. so i did some searching (admittedly, probably not enough but i am at work with my phone...) and am having a hard time sourcing more aggressive brake pads for my 79zx. i did find a few for 81 and later. has anyone got a decent source for some performance oriented pads? i would love to Eventually step up to bigger brakes but for now its gonna have to be somewhat budget friendly. am doing goodridge flex lines (if they ever get to my house) and have fresh rotors and stock pads at the moment. any suggestions??
D~
I believe hawk makes some pads for the front and rear. I'm currently using PBR ceramic pads, but I don't know how "performance" they are. I know tire rack used to carry hawk  pads, but just searched and can't find them.
MSA sells some:
http://www.thezstore.com/page/TZS/PROD/PBC01/24-5502
Also:
http://forums.hybridz.org/topic/101552-brake-update-280zx/
The front calipers as far as I know are the same, The rear calipers are not. The early calipers are called the elephant ear calipers, because of the giant piece of metal that looks like an ear. The also have a smaller bolt pattern (the two bolts used to bolt it up are closer together). Incidentally, my friend held up a newer porsche caliper and the bolt pattern was the same.
In order to change to the later style calipers, you need to swap the whole rear trailing arm/hub. Its not hard, and I probably should have done it when I was redoing my suspension, but I already had some decent pads, and the drilled/slotted rotors MSA sells. The rear calipers have the same bolt pattern as a 240sx, so you can use those calipers as bolt in I believe, the q45 calipers, or upgrade to the 300zx calipers with the use of a spacer.
Thought i would give this a bump. Also i would like to warn folks about an E-bay store called Kumera Motoring. I ordered Goodridge brake lines early this month and still have not received them. They did not communicate with me at all until i raised a big stink on e-mail, their phone machine, and E-bay. Turns out they didn't have them in stock like their ad stated. So now i am waiting to see if they get them in their order Wednesday (27th of Feb). After that they said they would refund me. Meantime i have been waiting just shy of a month for brake lines... Did i mention i am not at all happy with them???
I called, left messages, E-mailed, used E-bays forms. I will know more today hopefully. BTW... I had the spelling wrong. It is Kuruma Motoring. They are a So. Cal. business. Maybe i have been lucky so far, i have been buying parts from E-bay stores for quite a while and have never been blown off like these folks did.
