Zfan1 Posted February 20, 2013 Share Posted February 20, 2013 (edited) Can I use the stock alternator placement on an LS2 motor and have it fit under the hood of the 240Z without modifications? I am looking at an Alper Motorsports billet bracket since that is all I am running for now. It does not change the installation placement though. Thanks Mike Edited February 20, 2013 by Zfan1 Quote Link to comment Share on other sites More sharing options...
Daz Posted February 20, 2013 Share Posted February 20, 2013 You should be able to use the stock location ! Its the lower right side right ? Check this post :http://forums.hybridz.org/topic/110011-high-end-ls3-with-harrop-itb-t56-and-r230-build-log/ . Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted February 20, 2013 Share Posted February 20, 2013 I couldn't run a stock ls2 gto alternator no matter how much I cut down the ear bracket and the JCI driver side motor mount. (The alternator is longer and there is a screw on the front that will hit on your steering rack) Switched to a ls1 camaro style alternator and it bolted right in. Lots of pictures in my build thread (I think). The stock ls2 alternator bracket is the same as the camaro. The rear bracket is different but is available thru dealer for $9. The gto alternator plug is different so the harnes will need a small mod as well if you swap alternators. Quote Link to comment Share on other sites More sharing options...
Daz Posted February 20, 2013 Share Posted February 20, 2013 My bad ! I was wrong, I thought they were the same ! Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 22, 2013 Author Share Posted February 22, 2013 (edited) Thanks everybody, I am starting the swap this evening. Hoping to have it all wrapped up within 4-6 weeks. The headers will be custom built 1 7/8" by 3 or 3 1/2" , the guy building them needs to keep the car for a while, that will be the most time consuming. Edited February 22, 2013 by Zfan1 Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted February 22, 2013 Share Posted February 22, 2013 A 3 inch collector would be better, and 3 1/2 would just cause even worse clearence issues. 1 7/8 will also be a tight fit. Are you going with JCI Mounts or custom ones? -Will Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 26, 2013 Author Share Posted February 26, 2013 Broken Kitty/JCI, I just pulled the old motor, transmission, almost all the wiring, etc. My friend is going to help me weld up all the holes in the engine bay and grind the welds down. Then it's paint and wiring, then motor and trans. We picked up a 4L80E case for test fitting, damn it is going to be tight! Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted February 26, 2013 Share Posted February 26, 2013 If you are doing a drag car, look on the forum for the dude doing the 4.3 V6 swap. He somehow put his pedals and master cylinders INSIDE the firewall and ran his headers as dump tubes into his fender wells. That is badass and would solve a lot of the fitment issues with routing exhaust around the tranny. I'm doing my exhaust and it it hard enough to get around the T56. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 27, 2013 Author Share Posted February 27, 2013 Heck no! This car will be driven everywhere just like my other sbc set up, driven all over town and long hauls on pump gas running 9's in the 1/4. That is the only way to go, anyone can build a dedicated drag car, this will have heat and a/c tp boot...LOL I know the headers will be a son of a gun to say the least but I got to try...please don't laugh. I just need a bigger hammer Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 10, 2013 Author Share Posted June 10, 2013 Well found out I maybe screwed as the L76, LS2 with LS3 heads and intake doesn't supposably use the same accessories as a 2005-06 GTO LS2. What I have been told is the L76 out of the Pontiac G8 runs Corvette accessories. The difference is the Vette is 3/4" shorter on all accessories vs the LS2's meaning I will now have to figure out how to mount the alternator. I tried the high side with a new LS1 alternator and it hits the strut tower, low will probably be more of the same. Hate to have to buy all new accessories...damn! Quote Link to comment Share on other sites More sharing options...
Domzs Posted June 10, 2013 Share Posted June 10, 2013 (edited) I think all you need to do is to swap out the balancer to F body . You are right , the Vette is shorter . Don't use truck , they're longer . Edited June 10, 2013 by Domzs Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 10, 2013 Author Share Posted June 10, 2013 What about the water pump? Quote Link to comment Share on other sites More sharing options...
Domzs Posted June 10, 2013 Share Posted June 10, 2013 What about the water pump? It should be ok . The pulley is pretty wide . Try it and see . Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 10, 2013 Author Share Posted June 10, 2013 Question for the LS2 owners using the lower mount with LS1 alternator. How much clearance do you have in the back behind the alternator? The G8 L76 uses the Corvette short balancer but uses the lower GTO LS2 type alternator bracket/position. The problem is it pulls everything 3/4" of an inch back towards the front of the engine and I do not know if that will work with John's Car Mounts. Anyone have any pictures? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted June 12, 2013 Share Posted June 12, 2013 http://www.nookandtranny.com/mm5/merchant.mvc?Screen=PROD&Store_Code=NookandTranny&Product_Code=STM-EN03710&Category_Code= link for PS delete. Go on nookandtranny.com They have lots of motor swap information including a paragraph on front accy drive compatability. Quote Link to comment Share on other sites More sharing options...
shupee Posted June 14, 2013 Share Posted June 14, 2013 (edited) alper motorsports bracket is the best $95 I've ever spent on ebay.Here's a pic of mine for reference Edited June 14, 2013 by shupee Quote Link to comment Share on other sites More sharing options...
