Guest Anonymous Posted August 23, 2001 Share Posted August 23, 2001 im looking to build a L28 motor for my 71z is it possible to get 200 hwr out of it and what am i getting myself into i will spend up to 2000 if i have to to get that kind of power im tired of all the mustangs and camoros getting the best of me Quote Link to comment Share on other sites More sharing options...
RedNeckZ Posted October 30, 2001 Share Posted October 30, 2001 For the best dollar, you need to v-8. You can get 200hrp from the 6, but you are going to pay for it. It cost me around $3000 to do my last block L-28 with E-31 Head. Horsepower cost is better with the V-8, more for less. How big of a checkbook do you have to give? Check under the search engine and look at the info on the change, it isn't that hard to do. A simple engine change without a lot of mods will still give you more power per dollar. Good Luck. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 30, 2001 Share Posted October 30, 2001 For $2000 you can easily get 200hp out of an L28ET. The turbo motor stock with a little extra boost will do 200hp, which should put you slightly ahead of the offending Mustangs. I paid $750 for a running donor 280ZXT - there is very little extra expense bolting and wiring the motor and electronics. With an intercooler and a bigger fuel pump and injectors you can run low 13 - high 12 second 1/4s which blows them away. Quote Link to comment Share on other sites More sharing options...
DAW Posted October 31, 2001 Share Posted October 31, 2001 I agree. The L28ET was very undertuned from Nissan. Adapt an intercooler, run a rising rate fuel pressure regulator with a big pump, plug the manifold pop-off valve, install a compressor bypass valve, and increase the boost; and you've just picked up a lot of horsepower for a small investment. Quote Link to comment Share on other sites More sharing options...
