tomr240zap Posted April 6, 2013 Share Posted April 6, 2013 So i'm working on installing new ES poly bushings in my 240z and after reading a few online walkthroughs, figured i had it covered...Upon drilling/burning out the old bushing centers and installing the new bushings and metal bolt sleeves, i'm noticing that the old moustache bar bushing does not have a rolled over flange on both ends as i've seen on all other photos / tuitorials. I'm working with a rolled flange on one side and a straight lip on the other end that extends out almost half and inch or so. This is not permitting the two bushing halves to seat up against each other as well as not giving me enought thread on my stud to even get the nut/washer started upon installation. My initial thoughts were that i'll have to hack / grind this flange off, however i thought I had better check with someone before doing something irreversible...is this standard procedure for a moustache bushing install??? Quote Link to comment Share on other sites More sharing options...
Miles Posted April 6, 2013 Share Posted April 6, 2013 That is a stock OEM mustache bar bushing replacement. I used them on a stock 240Z years ago. Also, look here: http://www.classiczcars.com/forums/engine-drivetrain-s30/37044-stock-mustache-bar-bushing-flare.html It looks like you could cut off the extra length with a hacksaw. Quote Link to comment Share on other sites More sharing options...
tomr240zap Posted April 6, 2013 Author Share Posted April 6, 2013 Perfect. Thanks for the link, Miles!Will take the hack saw approach and get this thing back together. Quote Link to comment Share on other sites More sharing options...
