Front control arm
The stamping and holes are all the same, but the steel tube in the center of the rubber bushing that mounts it to the K-member is offset slightly, positioning the arm biased to the front of the car if I remember right (short space in front, long space in rear). You'de offset the control arm if you used a right on the left or visa versa. Its only maybe 1/2 difference, but would affect alignment specs.
If you're replacing bushings then it doesn't matter one bit. Just orient the new bushing spacers correctly for the side it's on.
My 78 Z came like this . Don't rec. swapping them .
As Jim already mentioned, the control arms are the same. It's the bushings that determine which side they're put on, as you can see in your photo.
