voltron_boi Posted May 8, 2013 Share Posted May 8, 2013 I have 2 cas that was working good. Just got done installing 1 of the Cas with the aem disc wheel. Put it on and attempt to start, no start . Took off that Cas, and install the one haven't ben modify. Now starts right up? Any one no what might the reson be? Quote Link to comment Share on other sites More sharing options...
djz Posted May 9, 2013 Share Posted May 9, 2013 This may be a silly question but what ECU are you using? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 9, 2013 Share Posted May 9, 2013 Surely an aem ems.... Make sure you have the AEM cam sensor loaded in your wizard... Open your tune, go to WIZARDS, then SETUP WIZARD, then under Sensor: Cam/Crank, make sure its NISSAN 4 & 6 COP, WITH AEM DISK. make sure its not the rb stock disk.. Assuming your on a V2 box. 1 Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted May 9, 2013 Author Share Posted May 9, 2013 I'm sorry to not make it clear. I have aem series 2 ems on a s1 rb25. It will work on the oem Cas, but not the Cas with the aem disk. Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted May 9, 2013 Author Share Posted May 9, 2013 On 5/9/2013 at 1:05 AM, ZT-R said: Surely an aem ems.... Make sure you have the AEM cam sensor loaded in your wizard... Open your tune, go to WIZARDS, then SETUP WIZARD, then under Sensor: Cam/Crank, make sure its NISSAN 4 & 6 COP, WITH AEM DISK. make sure its not the rb stock disk.. Assuming your on a V2 box. Tech who is working on my car say "Cam n crank sync are off, and I already talk to aem. The manufacture can't get any better, It's the rb wiring harness that Changes too many business, AEM said. so it needs to be wired to how AEM sync works. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 9, 2013 Share Posted May 9, 2013 Post a picture of your phasing. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 9, 2013 Share Posted May 9, 2013 (edited) Take your plugs out and turn off all fuel injectors. Have a friend spin the car over with the starter while you check the timing with a light. With your laptop go to Wizard, then Ignition Timing Wizard, lock the timing and click the show the Advanced options box. Now you will see Teeth. When click on the Advance or retard buttons the teeth number will go up and down. 24 is where you might have to set the teeth to 0. You only have to do this if your going a certain way, I cant remember if its advancing or retarding. 24 is the same thing as 0 so as the teeth increase make sure it doesnt hit the 24 ceiling, if it does put the number 0 in there and it will keep going. You click on buttons realtime as a friend spins it over. Mine was waaaay out on my RB30 vs the 26. Its kind of hard to see it at such low rpm but thats how I got mine cranked. Edited May 9, 2013 by ZT-R Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted May 9, 2013 Author Share Posted May 9, 2013 Could it be the wiring like the tech say, or is it the software from the ems? It's starts up with the oem Cas, but with the Cas with aem disc, it doesn't. ZtT-r, I will forward that to the tech that is working on my car and see if that works. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 10, 2013 Share Posted May 10, 2013 (edited) You cant just swap the cas disk and crank it, you have to change the sensors in the software. Its like running a 5bar map then installing a 3 bar map... not the same. Not saying that is the only issue, but an issue none the less. Edited May 10, 2013 by ZT-R Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted May 10, 2013 Author Share Posted May 10, 2013 Tech say I looked into it and there is many different ways, But AEM told me what is need to do on this harness case. On the software there is "test" ways to see what the Ecu is looking at and go from there after AEM told me how to test it, I told them what is happening. They said the 2 signal wire problem needs it's own signal that's how the AEM works. I ask why it works on others with OEM CAS wheel. They said the harness is different. The year they tested was 93-98 r33 GTS only cars, and all other are different. Rb25 came in alot of models in Japan, not just a skyline. I never new aem s2 would be this much of a headache. Should of just went with haltech. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 11, 2013 Share Posted May 11, 2013 Do you have a pinout of your harness? 1 Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted May 14, 2013 Author Share Posted May 14, 2013 I know rb25det comes in series 1 and 2, and have use the rb25 s.1 pinout to wire up my car. I look on both pinout for the Cas and wiring diagram and they both look the same. Hmm. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 14, 2013 Share Posted May 14, 2013 confirm by back probing the wires to the corresponding ecu pin. Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted June 11, 2013 Author Share Posted June 11, 2013 On 5/9/2013 at 1:05 AM, ZT-R said: Surely an aem ems.... Make sure you have the AEM cam sensor loaded in your wizard... Open your tune, go to WIZARDS, then SETUP WIZARD, then under Sensor: Cam/Crank, make sure its NISSAN 4 & 6 COP, WITH AEM DISK. make sure its not the rb stock disk.. Assuming your on a V2 box. That was done and still no start. On 5/9/2013 at 12:16 PM, ZT-R said: Take your plugs out and turn off all fuel injectors. Have a friend spin the car over with the starter while you check the timing with a light. With your laptop go to Wizard, then Ignition Timing Wizard, lock the timing and click the show the Advanced options box. Now you will see Teeth. When click on the Advance or retard buttons the teeth number will go up and down. 24 is where you might have to set the teeth to 0. You only have to do this if your going a certain way, I cant remember if its advancing or retarding. 24 is the same thing as 0 so as the teeth increase make sure it doesnt hit the 24 ceiling, if it does put the number 0 in there and it will keep going. You click on buttons realtime as a friend spins it over. Mine was waaaay out on my RB30 vs the 26. Its kind of hard to see it at such low rpm but thats how I got mine cranked. Lock the btdc at 15 degree, and had my freind crank. I set it at 0 while I use a timing light, and started to go untill it reach 15 degree on the timing mark cover. Once that was done, still no start either Btw, Was able to locate the cam and crank signal according to aem instruction, and also verified if its getting fuel and spark, and it does. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 11, 2013 Share Posted June 11, 2013 Take it to a competent tuner. 1 Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted June 12, 2013 Author Share Posted June 12, 2013 On 6/11/2013 at 11:58 PM, ZT-R said: Take it to a competent tuner. When u install yours did you do this? http://forum.aempower.com/forum/index.php?action=dlattach;topic=20346.0;attach=6108 I try looking for that tab on the laptop, but couldn't locate it. If you did, can u tell me how? If that doesn't work then competent tuner it is. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 13, 2013 Share Posted June 13, 2013 I'm running V2 which uses aem tuner, not aem pro. I would imagine thats under something like coils/injection. Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted June 13, 2013 Author Share Posted June 13, 2013 I was able to locate it after going through the troubleshoot tab section. Mine looks a bit different then the above. I was just wondering ZT-R, did you also have to do this to start ur car, because I haven't touch this section yet. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 14, 2013 Share Posted June 14, 2013 The v2 has wizards that does all that for you, but yes you will have to change it. Mine looks similar to that but my Injector Phase is 16.078 The injector and teeth (order) looks correct in the picture. Post some screenshots of yours. Quote Link to comment Share on other sites More sharing options...
