tooquick260 Posted May 30, 2013 Share Posted May 30, 2013 Wondering what nuts, or nuts and washers everyone is using to bolt there turbo to the exhaust manifold? Are you used anything special, do you use a lock washer. I removed my turbo and down pipe today to get the turbo inspected and rebuilt. 3 of the 4 nuts were on the loose side and 2 of the down pipes nuts were loose. When I re-install want to make sure that they stay tight. Quote Link to comment Share on other sites More sharing options...
Timecode Posted May 31, 2013 Share Posted May 31, 2013 (edited) As I understand lock washers are no good at the heat range those parts see. Edited May 31, 2013 by Timecode Quote Link to comment Share on other sites More sharing options...
Xnke Posted May 31, 2013 Share Posted May 31, 2013 You will have to keep up on them for a bit after the first few good heat cycles. Even with the locking tabs, I end up torquing them after the first hard drive, then again a few days later, then a week later...then they finally stay tight and I fold the locking tabs over. Quote Link to comment Share on other sites More sharing options...
Snailed Posted June 4, 2013 Share Posted June 4, 2013 I have had good luck with the long, brass nuts parts stores sell even on 4cyl applications. They are 3/8" and probably 7/8" long. You must retorque them a couple times though. They never gaul or break studs coming apart too. Locking tabs or safety wire or other mechanical locks are the way to go if you want to it to work every time. Running no gasket helps too. As gaskets settle or start to burn they seem to let the hardware loosen up. I get the manifold and turbine housing as flat as possible by block sanding and use a little copper spray to help seal any small imperfections. Quote Link to comment Share on other sites More sharing options...
tooquick260 Posted June 5, 2013 Author Share Posted June 5, 2013 Thanks Quote Link to comment Share on other sites More sharing options...
