dpuma8 Posted June 6, 2013 Share Posted June 6, 2013 I want to order a GT3076R .63 a/r with a T3 inlet flange and V Band outlet. There is an "option for compressor housings" and I do not know which one I should be using. My exhaust manifold has a T3 external waste gate flange welded on. Here is the link for the turbo I am ready to order. Any other tips or external wastegate recommendations along with size? http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=GRT-TBO-005 Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted June 7, 2013 Share Posted June 7, 2013 It doesn't look like you can get an undivided housing with a Vband. So I guess you have to either use that or go with the undivided 4 bolt 3" outlet Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted June 7, 2013 Author Share Posted June 7, 2013 The third option from the bottom isn't it? Quote Link to comment Share on other sites More sharing options...
calpoly-z Posted June 9, 2013 Share Posted June 9, 2013 Yeah the third turbine housing from the bottom should work fine for you. As far as compressor housings, I ended up going with the smaller T04B option for packaging issues when I ordered my GT3071. It's my understanding that the T04E housings require a spacer to clear the exhaust manifold. A lot of people use T04E housings though so I'm sure the default option would work fine as well, but you'll need a small spacer. Quote Link to comment Share on other sites More sharing options...
