EZpickenZ Posted June 8, 2013 Share Posted June 8, 2013 Ok. I've Looked On Both Suspension Pages And I Can't Find The Answer Im Looking For. Im Trying To Find The Angle Of The Front Spindle/Hub Compared To The Strut Housing. Has Anyone Posted This Info Here? If So, Please Point Me In The Right Direction. Sry For The Caps On Each Word. My Phone Has A Problem! Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Domzs Posted June 8, 2013 Share Posted June 8, 2013 If you are talking camber and caster angles then you need to look for alignment spec. Quote Link to comment Share on other sites More sharing options...
z240 Posted June 8, 2013 Share Posted June 8, 2013 how exact do you need? I get 106 deg. using an electronic angle gauge from spindle tip to strut housing Quote Link to comment Share on other sites More sharing options...
tech40799 Posted June 9, 2013 Share Posted June 9, 2013 I think it's around 11-14degrees, it's in the factory service manual. Quote Link to comment Share on other sites More sharing options...
EZpickenZ Posted June 9, 2013 Author Share Posted June 9, 2013 I Jus Bought A Angle Guage And Found That The Angle Is ~14°. Good call tech40799. Thanks For The Input Guys. Quote Link to comment Share on other sites More sharing options...
z240 Posted June 14, 2013 Share Posted June 14, 2013 Just for the sake of completeness, in the 71 FSM, on page BF-3 on the "Standard body dimensions" drawing, the angle is stated as 13 deg 45' Same thing in the 78 FSM. Nice measuring EZ, way better than my 16 deg gauge estimate! The Rear angle for interest sake, is 16 deg 15' Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted June 17, 2013 Share Posted June 17, 2013 And for those unfamiliar with degrees/minutes/seconds, that's 13.75 degrees and 16.25 degrees. Quote Link to comment Share on other sites More sharing options...
