madkaw Posted June 30, 2013 Share Posted June 30, 2013 I am laying out the ground work( pun intended) for my MS3x install. Grounding is very important and I want to get this right. Trying to keep things looking tidy and lack of grounding points on the engine makes things a challenge . I was considering a grounding busbar to handle all my grounds. The Megamanual states to run individual wires to the grounding point, so why not run them to a busbar that is directly grounded to the engine. Then you could mount the busbar to the firewall and run one heavy lead to the block. It would look much better then 8 individual wires running to one bolt somewhere. Any cons to this ? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted June 30, 2013 Share Posted June 30, 2013 I was doing something similar and it worked for me. I'm in the process of shielding my harness to get rid of the popular 'noise' that everyone with MS experiences. You may want to look into that while you're still building your harness. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted June 30, 2013 Share Posted June 30, 2013 I followed Cygnus MS 2 system build, He used a grounding bar as well as his own relays. Worked great for me. Quote Link to comment Share on other sites More sharing options...
