Atozone Tonine Posted June 30, 2013 Share Posted June 30, 2013 I learned a few tricks when installing my bumpers. ( as requested by California Highway Patrol) I bought some used ones and the rear must have been in a slight accident because the bolt flanges were bent and did not align with the body holes. Tip #1 Hammering then prying the side flanges on the rear bumper back into shape does not work we'll. cut a piece of wood about 1.5" x 1.5" and jam it under the flange. Stand it on its end the hammer it down. Works great. Tip #2 To attach the rear bumper, fasten the straight part to the body first, then attach the side flanges to the body next, then screw the sides to the straight part. Reason - if there is any irregularities, the holes will not align if you try to install the whole thing at once. Tip #3 Use some 1/2" (inside hole dimension) rubber bearings between the body and side flanges of the rear bumper. Gives good spacing. Quote Link to comment Share on other sites More sharing options...
