82 ZX Barely runs when cold (If Throttle is applied)
Connor280ZX
You said it runs great in #15...?
Popping and stumbling is typical of a bad AFM causing lean spots or just running on the lean side due to low fuel pressure.  I have two lean AFMs that work fine with the potentiometer in the water temperature circuit, adding a little fuel.
