240Z Turbo Posted April 11, 2002 Share Posted April 11, 2002 I have been battling belt slippage problems under full rpm and it is pissing me off. Does anyone besides Arizona Z car make pulleys for the L6 to run a serpentine belt? Thanks, any info is apprectiated! Quote Link to comment Share on other sites More sharing options...
Mike C Posted April 11, 2002 Share Posted April 11, 2002 I assume you are just doing a ribbed belt and not interested in a spring pre-loaded serpentine setup? Doesn't your motor have the trick balancer? It will be really easy to get a GM ribbed belt pulley for your 1 wire alternator. Seems that digging through March's catalogs should come up with a setup that could easily be adapted Since pulleys could be redrilled and shimmed at the water pump assuming you could find a pulley to pilot on the crank. If your motor was NOT the one with the modded damper, whoever that is should have and easy time with the ribbed belt pulleys! Quote Link to comment Share on other sites More sharing options...
